Disable Telnet on Pix 7
May 23rd, 2007
Hi all,
I was just wondering, is it just a case of not configuring allowed hosts that can connect ?
i.e. telnet 10.10.10.10 255.255.255.255 host
If i don't configure any of these, is that in affect disabling the use of telnet to the box or is there an actual command that i am missing that will turn off this functionality completely ?
Cheers
Jon Marshall Wed, 05/23/2007 - 07:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
No that should do it. If you don't allow any hosts with the telnet command then nothing can connect via telnet.
Jon
