Jtapi User Dropping Device Associations
May 23rd, 2007
I have opened two previous cases on the issue I am about to describe. Both times I have been told that the event can be seen however root cause can't be determined. I am hoping someone her might help shed some light on the issue for me.
My CCM cluster has 6 in it (1 Pub 5 Sub), version 4.0(2)sr2c and has 3 jtapi users for device associations. This cluster is within an IPCC Enterprise 6.0 sr8 environment.
Here is my problem:
Every so often for no apparent reason a jtapi user will drop (unnassociate) all of the devices associated with it. We then have to scramble and reassociate all the devices in order to get a production system back into working order (this is in an inbound call centre environment).
This is not a situation where we have inadvertantly unchecked the "Check All on Page" or the "Check All in Search" check box and updated to lose everything. Sadly we learned that lesson the hard way about 4 years ago.
The net affect of this issue is catastrophic for my operational group and I need to get an answer to why this is happening but I am not having much luck.
I can provide more information as required and any thoughts would be much appreciated.
Bill
**EDIT: I forgot to mention the cluster is Active Directory integrated.
ivillegas Tue, 05/29/2007 - 10:50
When the user is getting dropped do you get any error message or warning messages in the log files
