Partial failure on synch archive
May 23rd, 2007
When I run synch archive, primary cofig synch is successful but vlan config fails with the following error: Am I hitting the bug CSCsh39475? or it is something different.
VLAN RUNNING May 23 2007 11:19:29 TELNET: Failed to establish TELNET connection to - Cause: Authentication failed on device 3 times. Failed to detect SSH version running on the device. VLAN Config fetch is not supported using TFTP.
Joe Clarke Wed, 05/23/2007 - 08:27
This is something different. In this case, interactive authentication is failing on this switch. The vlan.dat cannot be fetched using SNMP/TFTP like the running and startup configs. To get the vlan.dat, RME logs into the switch either with telnet or SSH, then does a "copy flash:vlan.dat tftp:". If authentication is failing, that means you need to correct the username/password/enable password credentials in DCR, then perform the operation again.
nawas Wed, 05/23/2007 - 09:16
CDA and DCR come up okay on all the credentials such as community strings, telnet or ssh, enable by telnet and ssh. and the primary config fetch is successful. But I see one strange thing when I connect the device and do show log I see the syslog saying authentication failed from CiscoWorks. I have tried updating the device credientials several time but stil no luck. Any other suggestions?
Joe Clarke Wed, 05/23/2007 - 09:25
Get a sniffer trace of the config archive operation to one failing device. Filter on all traffic to that device.
