PRI EI/T1 Configuration Questions.
Answered Question
May 23rd, 2007
Hi all,
While I have used the channel-group and timeslot configuration command sets to configure the interface, can somebody explain me at the lowest detail what exactly these commands do and their significance separately?
Is the timeslot a channel? Does that mean if I use timeslot 1-6, I am actually configuring the interface to use channel 1-6?
What about channel group?
Detailed answers would be much appreciated, since I could not find clear enough answers on the net.
Kind regards.
Correct Answer by scottmac about 9 years 5 months ago
That's correct.
Good Luck
Overall Rating: 4.7 (3 ratings)
scottmac Wed, 05/23/2007 - 09:15
Channels = Timeslots
Channel groups allow you to logically establish a collection of channels/timeslots and give them different functions or behaviours. Sort of like a "Dialer" lets you assign multiple logical tasks to a single physical interface.
Good Luck
network_enginee... Wed, 05/23/2007 - 09:53
Hi Scott,
So, in other words "channel-group 1" is the logical collection one of timeslots n-n?
Kind regards,
Wilson Samuel Wed, 05/23/2007 - 10:18
Always remember the thumb rule of Channelized E1/T1 and PRI over E1/T1:
1. If Channelized E1/T1 = Channel-Group
2. If PRI on E1/T1 = Primary-Group
Also, if Channelized E1/T1 then you may bundle in any combination and use it e.g. for an E1 you may use Channel-group 1-16 or 1-5 or 1-30 and use it as an L-3 interface.
However with PRI, the moment you give the primary-group command it will create equalent BRI channels (30 for E1 and 23 for T1) .
You may find the links useful:-
Kindly rate if it helps.
Kind Regards,
Wilson Samuel
