Console connection to a IP Phone 7970
May 23rd, 2007
Is it possible to connect to a phone like you would connect to a console port of a gateway ?
I have a 7970 that does not start. All I get is a fixed green light on the speaker button. I tried the factory reset but then again nothing happens.
Olivier
Overall Rating: 3 (1 ratings)
o.artigny Wed, 05/23/2007 - 23:41
Hello Brandon,
We are using SCCP firmware.
Yes, it is the factory reset that I tried. It did not solve my problem.
It seems my 7970 is just good fro trash.
Thanks anyway for your help.
Olivier
o.artigny Wed, 05/23/2007 - 23:44
BTW, which one is the console port mentionned in the document ?
"You configure some settings by using telnet to connect to your Cisco MGCP IP phone and enter commands in a terminal window. You can also connect an ASCII terminal to your phone's console port to enter the same commands"
Brandon Buffin Thu, 05/24/2007 - 04:16
It's the port marked RS 232. I would recommend opening a TAC case on your phone.
Brandon
Paolo Bevilacqua Thu, 05/24/2007 - 05:51
Which factory reset have you tried?
After that the phone seeks a term70.default file on the TFT server, have you check availability of that file and monitored the TFTP exchange ?
Brandon Buffin Wed, 05/23/2007 - 08:53
I believe you can only use a console cable with a phone with an MGCP image. See the following link.
http://www.cisco.com/en/US/products/sw/voicesw/ps4967/prod_maintenance_guides_list.html
Have you tried the factory reset as described here in the following link? Make sure that you are powering the phone with an external power brick.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7970g_7971g-ge/firmware/7_0_2_sr1/english/release/notes/70702sr1.html
Hope this helps. If so, please rate the post.
Brandon
