keepalives to reestablish a dynamic to static tunnel?
Answered Question
May 23rd, 2007
Hi All,
I have a dynamic to static pix 501 to pix 501 os 6.3 configuration. I would like to use keepalives to re-establish the tunnel in case the tunnel goes down. Can this be done?
Correct Answer by acomiskey about 10 years 1 month ago
Theres a workaround for everything, you could have the pix at the far end use a local ntp or syslog server, this traffic would bring the tunnel up as long as it was defined as interesting.
Overall Rating: 5 (1 ratings)
acomiskey Wed, 05/23/2007 - 09:58
  • Green, 3000 points or more
You can use dead peer detection to ensure the tunnel doesn't go down...but I don't think that will bring it back up if it goes down.
isakmp keepalive 10
ed-rucker Wed, 05/23/2007 - 10:21
I've tried this (isakmp keepalive 10), to no avail. Thanks though.
acomiskey Wed, 05/23/2007 - 10:27
That doesn't keep the tunnel from going down? Or are you just saying it doesn't bring it back up?
ed-rucker Wed, 05/23/2007 - 10:35
it doesn't bring it back up. i'm trying to prepare for the unavoidable power or internet outage that would bring the connection down. i would like the static location to reconnect without effort from the customer on that end. :)
Correct Answer
acomiskey Wed, 05/23/2007 - 10:39
ed-rucker Wed, 05/23/2007 - 11:00
that's a good idea. a ping will bring it up. some type of ping utility would also work. i was just looking for a solution on the firewall.
unfortunately the way this has worked out, the static pix is at the remote site. that could be changed but it would be easier to work around it.
Thanks.
ed-rucker Wed, 05/23/2007 - 11:09
sorry, i'm kinda slow. a syslog service on the remote computer with the main office (dynamic pic) logging to the remote syslog should work. Think?
acomiskey Wed, 05/23/2007 - 11:19
Ya, same difference. As long as the computer has data to send. I was confused before which end was dynamic. What I should have said, since your main end is dynamic, is to have your pix or a computer syslog or ntp to something at the remote site.
ed-rucker Wed, 05/23/2007 - 11:26
no reason you would have known, that would be the logical way. thanks again :)
acomiskey Thu, 05/24/2007 - 14:21
palomoj,
Not sure if it matters but in his case the head end firewall was dynamic. Would that still work?
