No active PPPoE tunnels
May 23rd, 2007
I have set up a vpn network with the following commands:
vpdn group 1 ppp authentication chap
vpdn group 1 ppp authentication mschap
vpdn group 1 ppp authentication pap
vpdn group 1 ppp encryption mppe 40
access-list 101 permit ip 192.168.0 .0 255.255.255.0 192.168.1.0 255.255.255.0
ip local pool pptp-pool 192.168.1.1-192.168.1.50
nat (inside) 0 access-list 101
sysopt connection permit-pptp
vpdn group 1 accept dialin pptp
vpdn group 1 client configuration address local pptp-pool
vpdn group 1 client authentication local
vpdn username cisco password cisco
vpdn enable outside
our inside ip pool is 192.168.0.0, and obviously the vpn pool is 192.168.1.0
I get a connection with the microsoft client, but when I can't see the inside network, and when I show vpdn, I get the following :
Remote Internet Address is (client ip) Session username is (username), state is estabd
Time since event change 101 secs, interface outside
Remote call id is 32768
PPP interface id is 1
12 packets sent, 96 received, 408 bytes sent, 18329 received
Seq 13, Ack 95, Ack_Rcvd 12, peer RWS 64
0 out of order packets
%No active PPPoE tunnels
What am I missing?
tkaye@iasbet Thu, 05/24/2007 - 17:33
Is there an acl for traffic on the inside towards the outside? ifso does this permit the traffic?
Is there correct routing in place from the internal network to the firewall for the 192.168.1.x subnet?
Once connected, try telnetting from the vpn device to something internal and do a show conn pro tcp local internalip and check the output
hope that helps.
