VPN - Internet stops working
May 23rd, 2007
We have a Pix firewall here which has VPN configured (PPP)
Once connected to the VPN, I can access network resources w/o any issues. The only problem is that I can't get to the outside and access internet websites.
Is this normal? Or is there something mis-configured?
Thank You
acomiskey Wed, 05/23/2007 - 11:37
  • Green, 3000 points or more
Yes, that is normal unless you have split tunneling configured.
danny9797 Fri, 05/25/2007 - 06:59
Has anyone run in to any issues with the split tunneling configured? I know it's for security reasoning but when individuals are on the network locally, they're still exposed to the internet and all the garbage out there.
I still tend to agree that it should be left the way it is, i'm just looking for more concrete evidence on the disadvantages of enable split tunneling.
thanks
