cisco switch c2948g question
May 23rd, 2007
simple question, what is the comand to display the mac of all connected clients to the switch per port. the "show mac address-table address" command does not produce any such infomration. we're at 8.3(2) sw.
thanks much,
peter.
chris.lepa Wed, 05/23/2007 - 13:33
That model runs catOS, so instead of "show mac address-table " you'd use "show cam ".
rate if it helps you,
-Chris
