Error Updating Locale - all of a sudden
May 23rd, 2007
I am running CME 4.1 on a 2801. I have a number of phones registered and working. I have been testing the IP Communicator Soft Phone for some time without issue.
All of a sudden I start getting a message on the Soft PHone that says CM Down, features disabled. When I look at the status messages on the soft phone I get "error updating locale".
Debugs on the router - debug ephone - show "phone has unregisted abnormally".
A packet capture shows that the 2801 is seeing the soft phone a RST packet.
The odd thing is that this soft phone has been working for some time without issue. I installed a AIM-CUE a couple of days ago, but it was working after that install as well.....
The documentation I was reading tells me that the Error updating locale message that my TFTP path is incorrect or that the files are not valid. It says that I should have the following - but I never had them in the first place.
Check that these files are located within subdirectories in the TFTPPath directory:
?Located in subdirectory with same name as network locale:
?g3-tones.xml
?Located in subdirectory with same name as user locale:
?ipc-sccp.jar
?ipc-sip.jar
Any help would be greatly appreciated.
neesharm Wed, 05/23/2007 - 21:54
  • Bronze, 100 points or more
I understand that it was working before ..did we make any config chnages recently ?
what is the version of ip communicator ?
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a00807aae21.html
Also what IOS version are you running
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a00805acf50.html
HEATH FREEL Thu, 05/24/2007 - 04:22
Some changes were made, but I compared them to the previous config. I have added a 2 port FXO card and configred a dial-peer for them, nothing that I would have thought affected the Soft Phone specifically.
IOS - 12.4(11)XJ
IP Communicator - 2.0.2
HEATH FREEL Fri, 05/25/2007 - 11:54
I am at my wits end.....I have tried re-installing IP Communicator with no luck.
Anyone have any ideas?
Prince_Oladi2 Tue, 10/19/2010 - 08:04
I have the same issue as well. In addition, When you removed and re-install the IP communicator,
an Exceptional error "Unable to initialize support for Cisco Emergency Responder service.
Please consult your system Administrator" is generated.This is really kicking my head right now.
