Ciscoworks LMS 2.6 - can't archive startup config
May 23rd, 2007
Hi Folks,
Does anyone know how to fix this issue with some devices?
"CM0057 PRIMARY STARTUP Config fetch SUCCESS, archival failed for lacrt021 Cause: Internal error Action: Verify that archive exists for device. CM0061 PRIMARY RUNNING Config fetch SUCCESS for lacrt021, no change in configuration. "
Cheers, SteveK.
Joe Clarke Wed, 05/23/2007 - 13:44
You will need to look at the dcmaservice.log to see what this internal error is.
stevek1 Wed, 05/23/2007 - 14:09
I found this in the dcmsservice.log file for the device from my previous example:
"[ Wed May 23 15:55:12 EST 2007 ],INFO ,[Thread-4473],,updateArchiveOOB,839,JBP based immediate config collection for lacrt021
[ Wed May 23 15:55:13 EST 2007 ],ERROR,[Thread-4473],,deleteStartupConfig,1817,CM0003: Version $1 does not exist in archive $2 Cause: Version may have been deleted
[ Wed May 23 15:55:13 EST 2007 ],ERROR,[Thread-4473],,updateArchiveForDevice,1419,Error archiving config for lacrt021
[ Wed May 23 15:55:29 EST 2007 ],INFO ,[Thread-5],,updateArchiveOOB,839,JBP based immediate config collection for lacrt021
Thanks for looking at this Joe.
Joe Clarke Wed, 05/23/2007 - 15:27
This indicates archive corruption. If you remove this device from RME, then re-add, this problem should go away. Of course, the downside is that you will lose all history for this device.
stevek1 Wed, 05/23/2007 - 16:15
Thanks Joe, I expected that may be the case.
