ASA5510 and CSC issue
May 23rd, 2007
I am having a bear of a time here. I have a new ASA running 7.2, with a CSC-10. I addressed the CSC with 10.128.28.3.23, the inside interface is 10.128.28.1, which I setup as the gateway for the CSC. I cannot ping it, nor access it with ASDM, in fact I had to manually setup the CSC because the ASDM would fail to upload the wizrd config to the session. What am I doing wrong?
Overall Rating: 4 (1 ratings)
hoogen_82 Thu, 05/24/2007 - 09:51
  • Silver, 250 points or more
From your CLI you did try to ping any of the ipaddress in your inside segment?
I would ask you to run through the CLI mode again by using session 1 and then setting up your network configuration. Otherwise it should be working.
I would suggest you to have a look at these training modules which give great insight in setting up the CSC module.
http://www.cisco.com/web/learning/le31/le29/configuring_asa_pix_security_appliances.html
There is also a training module for the initial configuration of the CSC module.
Hoogen
Do rate if you find this post helpful :)
tahequivoice Thu, 05/24/2007 - 12:21
I found the initial problem was I'm an idiot and didnt connect the ethernet of the CSC to a switch. I am so used to CUE-NM with an ethernet jack that isnt used, that I just assumed it worked the same way with the SSM. I finally figured out how to get it to work, but not using the management IP, using the inside instead. For some reason I cant ping across from the management subnet to the inside subnet from the ASDM workstation, in fact I setup a layer3 switch to use for the gateway of the SSM so it can be accessed from the PC. I will read through the link you posted and see if that helps. Currently I have access to it so I can patch it to the latest rev, it is currently two behind, new in the box.
tahequivoice Wed, 05/30/2007 - 11:02
Are there any examples on networking the SCS and ASA so the SCS can be accessed and have internet through the firewall as well as off site access?
