two controllers on the same subnet
May 23rd, 2007
One of our office that already has 1 2000 controller needs to install another one. Can the new controller be on the same subnet as the old one or does it have to be on a different subnet?
thanks
Overall Rating: 4 (1 ratings)
ankbhasi Thu, 05/24/2007 - 06:05
  • Cisco Employee,
Hi Friend,
You can have both the controllers in same subnet as well as on different subnet.
If they are on same subnets things are bit easy.
I will recommend you to read this link and see if this helps you
http://www.cisco.com/univercd/cc/td/doc/product/wireless/control/c44/ccfig41/c41mobil.htm
Please come back if you have any doubts.
Ankur
*Pls rate all helpfull post
axfalk Tue, 05/29/2007 - 14:41
Thanks for your response...Is having a mobility group a requirement for inter-controller roaming? I can see a benefit of having a mobility group in controller redundancy, but other than that, what sets it apart?
thanks again...
rseiler Tue, 05/29/2007 - 17:47
  • Silver, 250 points or more
At a minimum, your 2000 controller is on *THREE* networks: The management interface, the AP manager interface, and *AT LEAST* one interface for an SSID.
Therefore, I don't understand your question. The mobility group will work as long as the controllers can communicate with each other. The more important question is what happens to the wireless client data once it leaves the controller.
In most all cases, multiple controllers *MUST* terminate the client VLAN traffic on the same layer 2 infrastructure. This limits the topology significantly.
Isn't the 2000 controller EOL and doesn't it have significant mobility restrictions anyway?
axfalk Tue, 05/29/2007 - 18:02
Thanks for your response. We have 2 controllers that are on the same subnet. Do I need to create a mobility group for clients to roam from an access point joined to one controller to an access point joined to the other controller?
Thanks again...
rseiler Tue, 05/29/2007 - 18:06
Roaming is an 8 hour conversation in itself, but I will answer your question with a 'yes', you should have a mobility group defined if wireless clients may move between APs associated with different controllers.
Roaming actually has much more to do with the wireless security in use, the config of the client and back-end user database, and the layer 2 connectivity of the multiple controllers.
If you are using WEP or WPA pre-shared-key with the same layer-2 termination on the controllers, then your users really aren't 'roaming' at all, they are constantly re-associating to the different APs anyway.
Roaming, in my mind, means 'fast roaming' meaning less than 100 ms. This would require either Cisco proprietary CCKM, or some of the *sort of* WPA2 fast-reconnect features.
