Command to find the Feature set in the Cisco IOS
May 23rd, 2007
Hi All
Can anyone help me out to find out the feature set used in the Cisco IOS
My Image file is rsp-pv-mz.120-26.S6b.bin on Cisco 7513 router.
"Show Version" did not give me the result.
Thanks Very much
Beno
Overall Rating: 5 (2 ratings)
spremkumar Wed, 05/23/2007 - 20:02
  • Red, 2250 points or more
Hi Beno
I did try with Software Advisor and feature navigator tool and found that rsp-pv-mz belongs to Service Provider feature set.
You can also verify the same using those tools but i didnt get the desired results for the exact file name which you have posted out here..
but still you can try out your luck in future..
http://tools.cisco.com/Support/Fusion/FusionHome.do
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regds
