ASA 5505 Easy VPN between two offices, connection drops
May 23rd, 2007
i have two sites using ASA 5505 Easy VPN. VPN connection works for some time but after some time it drops and i am unable to start the session. i have tried restarting both the firewalls but no use. remote site is using dynamic IP and local site is using static ip. it gives me the following error at local site(with static ip)
May 23 20:50:12 [IKEv1]: Group = mytunnel, IP =, Removing peer from peer table failed, no match!
May 23 20:50:12 [IKEv1]: Group = mytunnel, IP =, Error: Unable to remove PeerTblEntry
i have attached the configuration file too...
