How can i activate the do not disturb feature on callmanager 4.1
May 23rd, 2007
We would like to activate the do not disturb feature on our callmanager 4.1 we have serveral 7040's and 7060's
Thank you for your time
neesharm Mon, 05/21/2007 - 14:18
  • Bronze, 100 points or more
Cisco IP Manager Assistant (Cisco IPMA) provides call-routing capabilities and other features that can help managers and assistants handle phone calls more effectively.
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps5015/products_user_guide_chapter09186a00802d11c8.html
I strongly recommend you through complete documentation (although its a pain going thru 30+ page document )before you implement it whether you are using a wizard or not
charlotterob Wed, 05/23/2007 - 22:58
Yeah I will have to read this doc and its entirity..although its asking for my cco information, i am entering my info and its not taking it..Now the question is once i run the wizard will this affect my current ccm configuration?...or its something extra?...will the sequence of my current extensions will changed?
thank you for your time
neesharm Wed, 05/23/2007 - 23:07
try this link
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps5015/products_user_guide_chapter09186a00802d11c8.html
Looks like you are planning to run the wizard first (if its a production server ...I would refrain from doing it it might not break anything however production server is not for experiments ..( it will create partiton and CSS and other stuff )
charlotterob Wed, 05/23/2007 - 23:26
yes..I will have to implement a lab server for this particular request i guess i can have the .tar file from bars uploaded into the lab server and basically clone a publisher in order to replicate our current ccm config. i thank you very much for your help as well your time.
charlotterob Wed, 05/23/2007 - 22:31
How safe is to run the IPMA wizard? what exactly is the IPMA?
