vlan creating
May 23rd, 2007
Hi all
I wrongly assigned "native vlan x to one f0/x port" now I want remove that how what is the proper commands shall I give.
plz. give early reply.
thanks in advance
ilnaiduccna Wed, 05/23/2007 - 23:15
hi amit
how we can find it's trunk port or not
thanks for early reply.
Amit Singh Wed, 05/23/2007 - 23:21
Two ways:
1. Check the interface config " show run int fa 0/x" and check if command " switchport mode trunk " is present.
2.Use the command " show interface fa0/x switchport " to check the operational mode of the switchport.
HTH,Please rate if it does.
-amit singh
ankbhasi Wed, 05/23/2007 - 23:23
Hi Naidu,
Issue a command "sh interface switchport" and it will give you the output like
Switch#sh int gig1/0/23 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Alternatively you can issue a command
"sh interfaces trunk" and it will list all interface which are configured as trunk ports.
*Pls rate all helpfull post
