Cisco IOS
May 24th, 2007
I have a cisco 2501 router with 8 MB Flash.I have two leased line of same ISP.I want to configured multilink.Which IOS is supporting.I tried c2500-i-l.113-10,c2500-i-l.120-9,c2500-d-l.112-9.
arjunsawant Thu, 05/24/2007 - 02:10
Thanks for ur suggetion.but my router having Flash 8MB.And image u suggest require Flash 16MB.Is there any image which support 8MB flash and multilink.
mohammedmahmoud Thu, 05/24/2007 - 02:21
Yes you can use:
HTH, please do rate all helpful replies using the scroll box on the right,
Mohammed Mahmoud.
Amit Singh Thu, 05/24/2007 - 02:37
In addition to mahmoud's post, if you dont have enough flash on the router to store the image , you can boot the router using the TFTP and have the image located in the TFTP server. Point the router to boot statement " boot system tftp://ip address/file name.bin"
-amit singh
