Installing Unity 4.2
May 24th, 2007
I am installing Unity 4.2.1 on Windows 2003 server. When I try to run the preperation assistant, i click on cuspa.vbs and in tells me to double click on english. When i do this, the preperation asssiatant does not run. Nothing Happens. Has anyone seen this before?
neesharm Thu, 05/24/2007 - 01:12
  • Bronze, 100 points or more
Is CSA or virus scan enable?
3. Can you change the registry key in the server at this location to 0
HKLM\SOFTWARE\Active Voice\CUCA\ConfigSetup\HasCompleted=0 and re-run cuspa.vbs.
Derek McCormick Thu, 05/24/2007 - 01:26
CSA is not installed yet
Also under the active voice folder, there is only 2 files, default and SelectedDisplay language. Have you any other suggestions?
neesharm Thu, 05/24/2007 - 01:46
Can you launch/open "add and remove programs" if you get an error then try the steps given below
To fix this issue, run the following commands from a Command prompt in the
C:\WINNT\system32 directory:
regsvr32 mshtml.dll
regsvr32 shdocvw.dll -i
regsvr32 shell32.dll -i
Derek McCormick Thu, 05/24/2007 - 03:03
i ran these DLL files and still can't run cuspa.vbs. any other suggestions?
