Warning message
3750 disabling AAA
Anand Narayana Thu, 05/24/2007 - 02:07
  • Silver, 250 points or more
Hi Askher,
juz follow the steps.
3750(config)#no aaa new-model.
bjornarsb Thu, 05/24/2007 - 03:19
  • Bronze, 100 points or more
If this is a router in service, i believe that you do not want down-time. Use an acl in one of your other routers or firewalls on the way to the AAA server. Then when the 3750 has no access to the aaa server it will use local auth. if you have enabeled :
aaa authentication login default group tacacs+ local
HTH,
Bjornarsb
guruprasadr Thu, 05/24/2007 - 03:22
  • Gold, 750 points or more
HI Aksher,
In the Global configuration mode:
#no aaa new-model
For additional level:
#no aaa authentication login {default | list-name} method1 [method2...] global configuration command.
Pls Rate If Helps ! !
Best Regards,
Guru Prasad R
