simple question about power supply
Answered Question
May 24th, 2007
Hi to all,
Can i use a 5509's power supply for a 5513's power supply?
thanks.
Correct Answer by Amit Singh about 9 years 8 months ago
The power supplies from the C5513 and C5509 chassis are not interchangable. The C5513 takes power supply WS-C5508, while the C5509 takes power supply WS-C5518.
C5509
Power Requirements
Input current:
12.0A max. @ 100VAC 60Hz
6.0A max. @ 200VAC 50Hz
KVA rating: 1.3 KVA
Output power: 805 watts per supply AC or DC
Heat Dissipation: 1150 watts (3920 BTUs per hour)
Data Sheet
Catalyst 5509 Switching System
http://www.cisco.com/warp/partner/synchronicd/cc/pd/si/casi/ca5000/prodlit/5509_ds.htm
C5500
Power Requirements (one power supply)
8.0A @ 230 VAC 50 Hz
16A @ 115 VAC 60 Hz
KVA rating: 1.84 KVA
Power consumption: 1100W
Data Sheet
Catalyst 5500 Switching System
http://www.cisco.com/warp/partner/synchronicd/cc/pd/si/casi/ca5000/prodlit/c5500_ds.htm
HTH,Please rate if it does.
-amit singh
Overall Rating: 5 (1 ratings)
Correct Answer
Amit Singh Thu, 05/24/2007 - 02:50
C5509
Power Requirements
Input current:
KVA rating: 1.3 KVA
Data Sheet
C5500
16A @ 115 VAC 60 Hz
Data Sheet
-amit singh
