Regarding upgradation of router 3662
May 24th, 2007
I want to upgrade my router 3662.. Can u suggest me new router which is compatiable to 3662 router.
spremkumar Thu, 05/24/2007 - 03:09
Hi Ganesh
You can have a look at Cisco 3800 series routers which is projected as replaceable units for Cisco 3600 routers.
do refer the following link and check out which suits ur requirement..
You can look at number slots available the kinda modules it can intake and processing speed as well as throughput which it can handle ..
