Firewall Policy Mismatch
May 24th, 2007
I downloaded the new Cisco VPN client for windows Vista, and we used the same profile we are using with Windows XP. But when I try to connect using Windows vista I receive (Firewall Policy Mismatch) error..
Initializing the connection...
Contacting the security gateway at x.x.x.x... Authenticating user... Contacting the security gateway at x.x.x.x... Negotiating security policies... Securing communications channel... Secure VPN Connection terminated by Peer. Reason 435: Firewall Policy Mismatch.
Connection terminated on: May 23, 2007 22:05:18 Duration: 0 day(s), 00:00.00
Not connected.
However all XP users are working fine.. Any idea why? Thanks in advance..
Overall Rating: 5 (1 ratings)
dominic.caron Thu, 05/24/2007 - 05:22
  • Silver, 250 points or more
You might be hitting bug...
CSCsi26229 unity vista: integrated firewall not installed on vista
or
CSCsh02887 unity-vista: stateful firewall does not start.
*** Feature removed until ZoneLabs releases Vista compatible product.
If you force a firewall to be active in your policy, it will result in that message.
