mohammedmahmoud Thu, 05/24/2007 - 06:09
You can use "write erase".
HTH ,please do rate all helpful replies,
Mohammed Mahmoud.
ankbhasi Thu, 05/24/2007 - 06:14
Hi Dan,
If you just want to delete startup config issue
delete nvram:startup-config
if you want to delete all the files in nvram then you can go with any commands already mentioned by other experts.
Ankur
*Pls rate all helpfull post
chris.lepa Thu, 05/24/2007 - 06:19
yeah, on most devices you can either do:
erase nvram
or
erase startup-config
MUHAMMAD SHAHEEN Thu, 05/24/2007 - 08:05
just to add what everyone has said....
if this switch has been part of VTP domain then it will also VLAN.DAT file in the flash:
you should also delete that file (delet flash:vlan.dat)
Shaheen
