two "caller ID DN" on one CallManager
May 24th, 2007
hello everybody.
I have CallManager 3.2, one cisco 3662 with two ports. Can I install two "caller ID DN" with such configiration? and numbers with different "caller ID DN" have to go out from cisco through different ports.
thanks for your help
Brandon Buffin Thu, 05/24/2007 - 07:30
  • Purple, 4500 points or more
Yes, you can. Remove the Caller ID DN information from the gateway configuration. Setup the external phone number masks of your DNs to be the proper outgoing number. Check the box on your route patterns that says "Use Calling Party's External Phone Number Mask". This will work assuming that your carrier does not overwrite oubound caller ID.
Hope this helps. If so, please rate the post.
Brandon
