carenas123 Thu, 05/31/2007 - 07:06
  • Silver, 250 points or more
Cisco Router and Security Device Manager (SDM) is a tool that can be used to proactively manage Cisco IOS software-based router resources and security before they affect mission-critical applications on the network. Security Manager provides the ability to start SDM without the need for SDM to be installed on your router.
Antonio Brandao Thu, 05/31/2007 - 07:32
Thanks Carenas, for your reply,
Correcting....
the correct software is the cisco device manager for switches and don't SDM how i had mentioned..
...so why the dash board information doesn't appears ?
What can be my problem ?
At
Antonio
Zeek Ferraros Sun, 02/08/2009 - 16:18
I have the same problem.
Did you figure it out?
Please let me know if you have a solution.
Thank,
Zeek
Leo Laohoo Mon, 02/09/2009 - 13:39
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
2950 and SDM???? 2950 can't accomodate the SDM software. Are you talking about the Cisco Device Manager?
Zeek Ferraros Mon, 02/09/2009 - 14:35
3650... non of the switches with the web interface shows traffic on the ports.
I've tested in 10 of them.
Leo Laohoo Mon, 02/09/2009 - 15:13
  • Hall of Fame,
    2017 LAN, Wireless
Use 3rd party software, like Solarwinds. It's more accurate and you can create a report.
Leo Laohoo Mon, 02/09/2009 - 17:31
  • Hall of Fame,
    2017 LAN, Wireless
I used to use a software called CyberGauge (by Neon Software). The company was bought by SolarWinds in 2006.
