Native VLan on ASA 5510
May 24th, 2007
Is there a way to change the native Vlan for an interface on an ASA 5510 running version 7.2(2).
On each side of my firewall the native VLan is something other than 1. There does not appear to be a command similar to the native command on a switch when creating a trunk port.
Overall Rating: 4 (1 ratings)
srue Thu, 05/24/2007 - 07:58
  • Blue, 1500 points or more
The native vlan is whatever is assigned to the physical interface. The physical interface does not 'tag' packets using dot1q - indicitave of the native vlan. by default, the physical interface does not pass traffic. to get it to do so, simply use the nameif command.
