Inbound call blocking based on ANI
May 24th, 2007
Has anyone ever had to try and block calls from one specific outside caller with one specific ANI to one internal user?
mcthompson Thu, 05/24/2007 - 11:03
Hi !
Thanks for the response! No, all I have to work with is ccm 4.1(3) and mgcp gateways on both 6608's and cmm mods. :(
Matt
mcthompson Thu, 05/24/2007 - 11:22
hi!
you know, i read this document and it looks like the only way to reject calls is based on the dialed number. I want to know if there is anyway to block calls from a specific number... ???
thanks,
matt
Brandon Buffin Thu, 05/24/2007 - 11:26
Yes, in the translation profile, you can use "translate calling" along with the "reject" keyword in the rule to block callling numbers.
Brandon
