05-24-2007 09:46 AM - edited 03-05-2019 04:17 PM
I have a trunk on a 4948 to a Cisco 5513. The 5513 can't set any QoS options so I can't trust the dscp or cos on the trunk.
I have a vlan that handles the voice traffic (vlan 64). What is the access list that I would apply to the trunk interface to allow me to set the dscp on that vlan to a specific value? This is what I currently have for a pertinent config:
class-map match-all VoIP
match any
policy-map VoIP
class VoIP
set dscp cs6
I know that I need to set the class-map VoIP to match access-group <<access-list>> but I just don't know the config for the access list.
The other vlans I need to allow on that trunk are 65-68,192,172,241. Thanks for any help you might give me!
05-31-2007 07:09 AM
The Cisco Catalyst 4948-10GE offers superior per-port quality of service (QoS) features to help ensure that network traffic is classified, prioritized, and scheduled optimally to efficiently manage bandwidth-hungry multimedia, and time-sensitive and mission-critical applications QoS features (including DBL) on the Catalyst 4948-10GE, refer to the QoS on Cisco Catalyst 4500 Series supervisor engines overview at: http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_white_papers_list.html
05-31-2007 10:17 AM
Thanks for your reply but I have a regular 4948 (not the 10GE version). Also I know that it provides some QoS capabilities and I am currently using them but I was hoping someone could let me know how I tag a single VLAN on a trunk while still allowing non-marked VLANs on that trunk. I am pretty sure I need a ACL for that.
05-31-2007 11:38 AM
For VoIP, you'll need to mark it as "dscp ef", not "cs6". "CS6" is normally used for Ip routing.
