Deny Access from a Spammer
May 24th, 2007
Hello all,
I have an example here. I would like to block access to our mail server from a spammer using an access list. Can anyone tell me if this is correct?
Spammer: 201.86.141.99
Mail Server: 209.24.251.74
Would this be correct?
access-list access_list_name deny tcp 201.86.141.99 255.255.255.255 host 209.24.251.74 eq smtp
acomiskey Thu, 05/24/2007 - 11:47
Yes, or just use "host"
access-list access_list_name deny tcp host 201.86.141.99 host 209.24.251.74 eq smtp
access-list access_list_name permit tcp any host 209.24.251.74 eq smtp
access-group access_list_name in interface outside
Wilson Samuel Thu, 05/24/2007 - 12:09
Though I'm taking the conversation to a different level, however this configuration will not be able to solve the issue if the Spammer is using a Spoofed IP or what if the Spammer changes the IP?
I would suggest / recommend that its quite unwise these days to NOT to have a good Anti-Spam software and by the way I have found that TrendMicro is one of the best AV / Security suite I have ever come across.
Kind Regards,
Wilson Samuel
danny9797 Fri, 05/25/2007 - 05:59
Thanks for the responses. Samuel, I do agree, it will only help to a certain extent temporarily. I would love to get an external spam based firewall setup.
I'm just curious with using access lists.
I can also use this command if I don't want a bad address to get anywhere:
access-list access_list_name deny tcp host 201.86.141.99 any eq smtp
This would be correct, right?
Also, what is the difference if I we're to use a subnet mask after I.P? I know on the router you can specify the amount of hosts (ie, 0.0.0.15). Can you do the same on firewalls?
access-list access_list_name deny tcp 201.86.141.99 0.0.0.10 host 209.24.251.74 eq smtp
Would this block all i.p's from 201.86.141.99-201.86.141.109?
acomiskey Fri, 05/25/2007 - 06:06
"I can also use this command if I don't want a bad address to get anywhere:
access-list access_list_name deny tcp host 201.86.141.99 any eq smtp"
Yes.
"Also, what is the difference if I we're to use a subnet mask after I.P? I know on the router you can specify the amount of hosts (ie, 0.0.0.15). Can you do the same on firewalls?"
You specify the subnet mask in firewalls, not a wildcard.
access-list access_list_name deny tcp 201.86.141.0 255.255.255.0 host 209.24.251.74 eq smtp
This would deny the entire 201.86.141.0 network.
"host 209.24.251.74" is also the same as "209.24.251.74 255.255.255.255"
