Categorize call from keypad
May 24th, 2007
I am trying to make an application that allows to a phone operator to categorize a call. For an example if is a client that have called, he only have to press key 1, if is an claim he will press the keypad 2.
When I was looking for the information about events that can tell me that the key was pressed, I have found something that it looks to work.
The code is as follows:
Address address = provider.getAddress("355");
Terminal terminal = provider.getTerminal("355");
ComponentGroup groups[] = null;
if (terminal instanceof PhoneTerminal) {
groups = ((PhoneTerminal) terminal).getComponentGroups();
Component components[] = groups[0].getComponents();
System.out.println("Component: "+ components);
for (int i = 0; i < components.length; i++) {
if (components[i] instanceof PhoneButton) {
PhoneButton but = (PhoneButton)components[i];
log.info("Phone Button Info: " + but.getInfo());
log.info("Phone Button Name: " + but.getName());
} catch (Exception excp) {
excp.printStackTrace();
But the problem is that I can't convert the Terminal to a Phone Terminal.
It's necessary to configure something in the device settings of CCM Admin? Or am I going on the rong way to this
Ana Soares
stephan.steiner Fri, 05/25/2007 - 02:10
  • Silver, 250 points or more
PhoneTerminal is a class from the javax.telephony.phone class - the Terminal returned by the provider is a javax.telephony.Terminal class, or more specifically, Cisco's implementation thereof (so a com.cisco.jtapi.extensions.CiscoTerminal). In the JTAPI documentation, you'll also find a list of what Cisco supports of JTAPI (their provider is an incomplete implementation of JTAPI 1.2) - you'll notice that the entire javax.telephony.phone package has not been implemented.
However, it's easy to get digits via JTAPI.. the developer guide even mentions how - if you search for "digit" you'll find
CiscoTerminal Filter and ButtonPressedEvents?Enables applications to
receive the CiscoTermButtonPressedEv when a digit gets pressed on the
phone.
And a whole chapter on
Reading that section should help you get started. You just need a terminal listener and process the appropriate terminal event and you'll get your digits.
soares.ana Fri, 05/25/2007 - 08:08
hi, Stefan
Thank you for your answer, it realy helps.
Ana Soares
