PA for DS-3
Answered Question
May 24th, 2007
Hi All,
I have had never been able to understand on whose recommendation (I mean if we need to check with the carrier or not) we need to buy PAs for a 7200VXR for DS-3
I have come across ATM PA-A3 and the PoS PA both could be used to connect the DS-3, so which of the PA should be used?
Wilson Samuel
Correct Answer by mohammedmahmoud about 9 years 9 months ago
Absolutely right.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Overall Rating: 4.3 (4 ratings)
mohammedmahmoud Thu, 05/24/2007 - 12:18
ATM PA-A3 is an ATM interface and the PoS PA is s PPP interface, its your call according to the other end to be connected, the carrier will provide you with DS3, using ATM or PPP is your choice if both devices are yours, and you'll have to check with him if you are taking internet access and the other device is his.
Mohammed Mahmoud.
Wilson Samuel Thu, 05/24/2007 - 12:22
Hi Mohd.,
So if I'm taking it correctly whenever one orders for a DS-3 he has 2 choices: 1. PPP 2. ATM
If PPP is the choice the PA required would be PoS PA and if the choice is on ATM then it would be ATM-PA-A3?
Wilson Samuel
Wilson Samuel Thu, 05/24/2007 - 12:39
Hi Mohd.,
Thanks a lot, also so may I safely conclude that:-
1. For any DS-3 and/or OC-3 could be connected via 2 L-2 technologies a.PoS b.ATM
If I choose ATM then I have to take the PA-A3 otherwise it would be PA-PoS?
Wilson Samuel
Correct Answer
mohammedmahmoud Thu, 05/24/2007 - 12:47
Absolutely right.
Mohammed Mahmoud.
Wilson Samuel Thu, 05/24/2007 - 12:50
Oh Boy,
You have answered me a million USD question, nevertheless I wonder why I didnt do a little more thinking.. :-)
May be its time for my brains to reboot (take a sleep)
Whatever, thanks a lot man..
Wilson Samuel
mohammedmahmoud Thu, 05/24/2007 - 13:00
You are always welcomed, please always ask there is always someone who likes sharing his info.
Just to consolidate your case, POS PA supports PPP, HDLC-like, and Frame Relay, while ATM PA supports only ATM.
Good Luck, and good night :)
BR,
Mohammed Mahmoud.
