CW LMS system crash
Answered Question
May 24th, 2007
Hi all,
LMS has crashed for an unknown reason. I was unable to log on this morning so jumped onto the server and tried a net stop / start crmdmgtd with the result:
C:\WINDOWS>pdshow
ERROR: connect to dmgtd process on "127.0.0.1" on port 42340 failed:
C:\WINDOWS>net stop crmdmgtd
The CiscoWorks Daemon Manager service is not started.
More help is available by typing NET HELPMSG 3521.
C:\WINDOWS>net start crmdmgtd
The CiscoWorks Daemon Manager service is starting.
The CiscoWorks Daemon Manager service could not be started.
The service did not report an error.
More help is available by typing NET HELPMSG 3534.
C:\WINDOWS>
LMS 2.6 on W2k3. No changes on the server recently. Last updates were the Windows updates earlier this month.
Starting CW Daemon in Win Services results in a start and then a stop 1-2s after.
thanks,
Marty.
Correct Answer by Joe Clarke about 9 years 9 months ago
Try running NMSROOT\setup\support\resetCasuser.exe, follow the on-screen prompts, and then see if dmgtd will start.
Overall Rating: 4.5 (3 ratings)
Joe Clarke Thu, 05/24/2007 - 14:17
What messages, if any, do you see in the Windows Event viewer? Look at the Application and Security logs.
Correct Answer
Joe Clarke Thu, 05/24/2007 - 17:15
martyyates Thu, 05/24/2007 - 18:30
that did the trick Joe. Any ideas on why it may have happened?
thanks,
Marty.
Martin Ermel Fri, 05/25/2007 - 00:52
Hi Marty,
You should not touch the following paths with your backup software, because these are the database folders from CiscoWorks; even if your SW would be able to backup these open files (but its actually not, as you see on the errors in the security log) they are useless. You have no garantee that the databases would be consistent!
It would be better to exclude them from your current backup.
\\aklnm003\c$\Program Files\Internetwork Performance Monitor\Server\Sybase\IPMDB.db
\\aklnm003\c$\Program Files\CSCOpx\databases\
Instead schedule the database backup in LMS and make sure the folder where these backups reside are included in your backup.
martyyates Sun, 05/27/2007 - 16:39
Hi Martin - thanks for the advice. Will tell TSM to avoid those dirs.
nice one,
Marty.
abulebdah Tue, 05/29/2007 - 16:11
Now I am facing the same problem,but after I apply
C:\Program files\CSCOpx\setup\support>resetCasuser.exe
then select option 2,I enter the new password, I got an error message
"The password does not meet the password policy requirment. check the minimum password length,password complexity and password history requirement"
any advice
martyyates Tue, 05/29/2007 - 16:21
Hi there,
do a net stop / start then run resetCasuser.exe and select option 1 (not 2).
Seems as though I have to run the exe each time I restart the app now...
- Marty.
Joe Clarke Tue, 05/29/2007 - 16:52
This should not be necessary unless something else on the machine is changing casuser's password, or modifying the local security policies.
Joe Clarke Tue, 05/29/2007 - 16:54
If you choose to specify your own password for casuser, you must specify a password that meets your system's password requirements.
