Truncating Numbers
May 24th, 2007
Hi there,
We have a problem with our phones in that when dialling an internal phone number using an STD code it will drop the last 2 digits and not dial the destination.
For example:
If you dial 65861234 the number will dial no problem but if you dial 0265861234 it will only dial 02658612 dropping off the last 2 digits.
External phone numbers seem to work no problem, it only seem to be doing this to registered numbers in the system.
Any assistance appreciated.
Dan
Chris Deren Thu, 05/24/2007 - 18:46
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Seems that you may have some overlaps, perhaps a translation pattern that matches only 8 digits, such as XXXXXXXX. I suggest using Dialed Number Analyzer to analyze your dial plan.
Chris
daniel.akinin Thu, 05/24/2007 - 19:44
We have used the dial analyzer and it is telling us that the call should work, any other suggestions on what to look for?
Dan
