Large number of Speed Dials
May 24th, 2007
I'm migrating a site that has over 150 speed dials configured. Does anyone have any suggestions? I don't believe I'm going to be able to due this using speed dials since the limit appears to be 99. I was thinking that translation patterns maybe my only choice. I'm currently running CCM 4.2. Tx
Overall Rating: 2 (1 ratings)
Chris Deren Thu, 05/24/2007 - 18:48
Are these system speed dials that everyone is using? If so then TPs are you best bet, unfortunately there is no Bulk way of importing TPs until CM 6.0. Your best way if you dont want to do manual TPs, is to create dummy cti ports or cti route points with the forwardAll destination configured.
sandonen Fri, 05/25/2007 - 02:06
The Speed dials are for everyone.
I was afraid that this might be the case.
Thanks for the info.
twissam Sat, 05/26/2007 - 01:28
how do you share the 150 speed dial?
what is the step by step setup.
Good day
s.schiassi Sat, 05/26/2007 - 01:31
create 150 translation patterns and put them on a partition that is cointained by everyone's Calling Search Space. In this way you can "share" them.
twissam Sat, 05/26/2007 - 01:35
make sense, i though you can put them in the directory services.
Good day
