05-24-2007 09:30 PM - edited 03-09-2019 06:03 PM
R8 Configure
username cisco access-class 10 passs 12345
access-list 10 permit R7's seriel IP
It don't work.Who can explane and how to do
Tks!
Configure R8 so R7 can telnet into R8 using the IP address
of the serial 0/0/0 interface on R8 using the username cisco and the
password 12345. No other routers or hosts should be able to telnet to R8
using the same username and password.
05-24-2007 10:38 PM
Can you try this
username cisco pass 12345
access-list 10 permit R7's serial IP
line vty 0 4
access-class 10 in
login local
transport input telnet
line vty 5 15
access-class 10 in
login local
Hoogen
Do rate if this helps :)
05-24-2007 10:58 PM
Thanks reply
Only R7 can access
We need can access from anywhere but the username only for from R7
R7(serial IP) telnet to R8 then cisco/12345 success
but R6 or others telnet to R8 and type username/password can't accept
