Subscriber Upgrade 5.0 to 5.1
May 25th, 2007
hi
i upgraded my CCM from 5.0.4 to 5.1.1 the publisher has been upgraded using freeftpd now i'm trying to upgrade subscriber with the same file i used for publisher (file name: cisco-ipt-k9-patch5.1.1.3000-5.tar.gz.sgn about 1.2GB)
the problem is that CCM cannot see the upgrade file (.sgn) in the ftp directory it gives the following error:
((Errors encountered.
The directory was located and searched but no valid options or upgrades were
available. Note, a machine cannot be downgraded so option and upgrade files for previous releases were ignored)).
did any one encounter like this problem?!
please help
didyap Thu, 05/31/2007 - 07:14
  • Silver, 250 points or more
check whether the file name is correct cisco-ipt-k9-patch5.1.1.3000-5.tar.gz.sgn .
The problem is that the file as downloaded from Cisco is compressed with a gz.gz extension. In order to process the upgrade file, it must be in uncompressed format with an extension of .sgn.
