VMS secmon and Trigger Packet
May 25th, 2007
Right, in the network is a VMS Server 2.3sp2 and several 5.1.5E1s283.0 sensors. We have enabled the following commands on the sensors:
overrides produce-verbose-alert
override-item-status Enabled
risk-rating-range 50
SDEE events are received in VMS SecMon console. In the past with this enabled, when the Risk Rating was above 50 on any event received in the console, this would produce a (verbose) trigger packet that would be viewable on the console by right clicking the event and the selecting tools/trigger packet. However it seams that this is not the case anymore.
Could someone tell me if this function still works or has something changed that makes it not possible anymore?
Overall Rating: 3.5 (2 ratings)
rhermes Fri, 05/25/2007 - 08:44
  • Gold, 750 points or more
Check to see if you are still reporting Risk Ratings on your events in SecMon. We have had some senor updates break Risk Ratings. Re-importing the sensor in VMS fixes that problem.
darin.marais Wed, 05/30/2007 - 00:35
If I run show event on a sensor were I have enabled the commands:
The event that is captured on the screen is as follows.
sensor# sh events
evIdsAlert: eventId=removed severity=high vendor=Cisco
originator:
hosted sensor
appName: sensorApp
appInstanceId: 5037
time: 2007/05/30 08:05:57 2007/05/30 10:05:57 CET
signature: description=Cursor/Icon File Format Buffer Overflow id=5442 version=S137
subsigId: 0
sigDetails: Malicious ANI File
interfaceGroup:
vlan: 0
participants:
attacker:
addr: locality=OUT removed
port: 8080
target:
port: 46531
context:
fromTarget:
text removed
fromAttacker:
text removed
riskRatingValue: 60
interface: ge2_0
protocol: tcp
The event includes the risk rating value. Is that what you mean?
In the past the events collected were IDIOM events but now the are SDEE. Is there a difference as far as the triggered packets are concerned. In the past the event included a section called triggerPacket but I don?t see that anymore.
