Path selection due to Wan failure
May 25th, 2007
HI,
In an H323 enviroment you configure 2 dial peers, (one voip and one pots)with the same destination-pattern but different preference to have the gateway
to do a path selection if a WAN failure arise.
How can I have the same functionality in a MGCP enviroment? Do I have to use the AAR functionality to reroute calls through PSTN instead paketnetwork or is there another way to do this?
sohaildxbfze Fri, 05/25/2007 - 02:20
hi,
u can define all ur gateways (including pstn, voip) in different route groups with priority in selection list, then include those route groups in route list again in priority order list.
