How to convert a "autonomous configuration" in a WLC config ?
May 25th, 2007
I have co convert ap from autonomous to ligh and i have to migrate the configuration and i don't know how in this case.
The client make 1 SSID with 2 differents auth method:
"dot11 ssid PROD
authentication open eap eap_methods
authentication network-eap eap_methods
encryption key 2 size 128bit xxxxx transmit-key
encryption mode ciphers tkip wep128
So, I can't make the same SSI with 2 profile in WLC4.1 because WEP and 802.1X is the same L2 policy...
Thanks for you help
ankbhasi Fri, 05/25/2007 - 01:57
Hi Friend,
I believe the best option will be to have one profile with wpa1/2 with 802.1x key management and wep on second profile.
Ankur
*Pls rate all helpfull post
Trending Topics - Security & Network
