Add Prefixes with Translation Rule
May 25th, 2007
Hi,can somebody help me with translation-rule.
I need add prefixes to individual called numbers.
My scheme:CCM4(77xxx dial plan)<->7204VXR<->Meridian(72xxx,73xxx dial plan)
Example:
Number from ccm 77001 calls to some numbers 72001 73001,call go thrue 7204VXR were to the called numbers add prefixe "6",like 672001 673001.
If I use something like this, it works,but for all who go thrue dial-peer 10.
voice translation-rule 1
rule 1 /^/ /6/
voice translation-profile profile1
translate calling 1
dial-peer voice 10 pots
translation-profile outgoing profile1
And I need to add prefixes only to individual numbers.
Overall Rating: 4 (2 ratings)
Aaron Harrison Fri, 05/25/2007 - 04:44
  • Community Spotlight Award,
    Member's Choice, May 2015
You can be more specific on the numbers matched:
rule 1 /^\(7....$\)/ /6\1/
Would prefix a 6 to any 5-digit number starting with a 7.
Aaron
Please rate helpful posts...
Brandon Buffin Fri, 05/25/2007 - 04:46
  • Purple, 4500 points or more
If you only want to translate calls to 72001 and 73001, you could use a configuration like:
rule 1 /^72001$/ /672001/
rule 2 /^73001$/ /673001/
translate called 1
Hope this helps. If so, please rate the post.
Brandon
kavalsky_a Sun, 05/27/2007 - 21:53
voice translation-rule 2
rule 1 /^\(77555$\)/ /6\1/
voice translation-profile 2
translate called 2
dial-peer voice 77 voip
tone ringback alert-no-PI
destination-pattern 77...
progress_ind setup enable 1
voice-class codec 1
session target ipv4:10.10.0.50
no vad
dial-peer voice 72 pots
tanslation-profile incoming 2
translation-profile outgoing 2
preference 1
destination-pattern 72...
progress_ind setup enable 3
progress_ind alert enable 8
direct-inward-dial
port 1/1:15
prefix 72
Here is my config,but it dont do what I need.
If I understand correct "translation-rule 2"
adds prefix 6 to number 77555 when someone called on 77555 (if 72001 call to 77555 it calls to 677555)
I try to explain what I need again.Here my Scheme.
CCM4(77...)<-->7204(dial-peer 72... ,73...)<-->Meridian(72... , 73...)
If I call "ONLY" from number 77555 to 72001,73002,73002... I need add prefixes to numbers where I calls from 77555(672001,673002,673002...)
