STM-1 + PPP Multilink bundle
hetene_kaz
There are two 7206 in two cities. Each has PA-STM1.
Connecting two 7206 to each other is done via SDH, then PPP Multilink bundle with 8xE1 in it was set up. It is maximum quantity of E1 for multilink interface. So, I have 16mbit/s link.
I want to expand my link. It's impossible to set up the second Multilink because Cisco says:
029778: May 23 19:25:30.714 ALM: Se2/0.1/1/4/2:0 MLP: Request add link to bundle
029779: May 23 19:25:30.714 ALM: Se2/0.1/1/4/2:0 MLP: Adding link to bundle
029780: May 23 19:25:30.714 ALM: Serial2/0.1/1/4/2:0 MLP: Local MRRU or peer MRRU does not match that of bundle akt-oup0-bb1
Is the solution to unset the Multilink to separate 8 interfaces, to add, for example, 8 E1 more, to assign p2p addresses to each pair and to do load balancing between 16 parallel p2p's??
Or are there any other ways?
OK. It seems the documentation applies to older IOS but there are now in 12.4 novel waysto discriminate among bundles.
Please try
interface multink 1
ppp multilink endpoint string
Also, seems you can set a larger number of links now:
ppp multilink links maximum 16
and in global config:
multilink bundle-name rfc
I understand that all this is quite confusing, unfortunately I don't have an adequate platform to test that now.
6 Replies 6
paolo bevilacqua
with multiple MLP bundles between routers, you will need to configure usernames for each bundle.
Please see:
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_configuration_example09186a0080093c1d.shtml
Doesn't work...
Here is a config:
interface Multilink1
description backbone link 1
ip address 17.x.x.25 255.255.255.252
ppp chap hostname parallel_multilink_1
ppp chap password xxx
ppp multilink
multilink-group 1
interface Multilink6
description backbone link 2
ip address 17.x.x.1 255.255.255.252
ppp multilink
multilink-group 6
On the second side config is identical.
As I think, "parallel_multilink_1" must be shown in "show ppp multilink" command output.
But even shut->no shut doesn't change this name. Everytime I see:
atr-pp6-bb#show ppp multilink
Multilink1, bundle name is akt-oup0-bb
Bundle up for 00:08:58
0 lost fragments, 226306 reordered, 0 unassigned
0 discarded, 0 lost received, 131/255 load
0xCC2E9 received sequence, 0x11C6E9 sent sequence
Member links: 4 active, 0 inactive (max not set, min not set)
Se2/0.1/1/3/2:0, since 00:08:58, last rcvd seq 0CC2E7
Se2/0.1/1/1/1:0, since 00:08:58, last rcvd seq 0CC2E8
Se2/0.1/1/1/3:0, since 00:08:58, last rcvd seq 0CC2E5
Se2/0.1/1/1/2:0, since 00:08:58, last rcvd seq 0CC2E6
There is never a word about "parallel_multilink" or "parallel_multilink_1" here.
If I shut down Mu1, Mu6 goes to Up, but still with name "akt-oup0-bb".
Also my IOS 12.2(25)S4 doesn't know command:
atr-pp6-bb2(config)#interface Multilink6
atr-pp6-bb2(config-if)#ppp authentication chap
% Invalid input detected at '^' marker.
have you configured:
as per documentation link above ?
Of course, yes. But when I make "show run", i do not see this command. I suppose it's a default.
Please try
interface multink 1
I tested the feature on a test platform that I got an access today to. So it works. But only on test platform (2811+2611xm).
I think my IOS on 7206 is not appropriate for the feature. I tried everyting - no result.
Thanks for answers.
