Richard Burts Fri, 05/25/2007 - 06:06
John
I have not done object tracking on an 1841 so can not speak from experience about this. But I am confident that object tracking is supported on the 1841.
Rick
spremkumar Sun, 05/27/2007 - 19:38
To add up to the replies posted by fellow netpro's Cisco 1841 supports Object Tracking subjected to that you have required feature set installed in it.
We do normally use Advanced SP Services to have the same .So do make sure that you have this feature of the ios code to have OB tracking feature enabled on your router..
regds
foxbatreco Mon, 05/28/2007 - 07:23
Hii..
if am correct it should have the advipservice-K9 IOS for Object tracking configs.
Amit Singh Mon, 05/28/2007 - 07:36
Yes, it is supported in Advanced Ip services. You need atleast 256MB DRAM for the same. You have to upgrade the memory and flash on the router for the same.
-amit singh
