Upgrade CallManager for 7911 phones
May 25th, 2007
I have Call Manager version 4.1(2) and I don't have Cisco IP phone 7911 in Device Defaults configuration. So, 7911 will not register on CCM.
How can I upgrade Call Manager to suport 7911 phones?
Is it posible to install a new device pack version and reload cluster to get suport for 7911?
Michael Whaley Fri, 05/25/2007 - 06:13
I am not familure with the 7911 first hand, but this was on the 7911G product page FAQ:
Customers are required to use the most recent version of each Cisco CallManager train for full support: Version 3.3(5)SR1, 4.0(2)SR2b, or 4.1(3)SR1.
Rob Huffman Fri, 05/25/2007 - 06:17
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Vlaho,
You would need to upgrade CCM to a minimum of 4.1(3)SR1 :(
Have a look at the following;
Supported CallManager Versions
This Cisco IP Phone 7911G firmware release is supported with the following Cisco CallManager versions.
Cisco CallManager version 3.3(5) SR1 or later
Cisco CallManager version 4.0(2a) SR2b or later
Cisco CallManager version 4.1(3) SR1 or later
Cisco CallManager Device Packs
You should install the following device packs for these Cisco CallManager versions.
3.3(5)SR1 - ciscocm.3-3-DevPack-65.6.exe, or later
4.0(2a)SR2b - ciscocm.4-0-DevPack-44.6.exe, or later
4.1(3)SR1 - ciscocm.4-1-DevPack-25.3.exe, or later
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/prod_release_note09186a00805b0439.html#wp1031083
Hope this helps!
Rob
vjemin Fri, 05/25/2007 - 06:23
OK. So I need to upgrade from 4.1(2) to some later version.
Do you have some document on which version I can upgrade?
