2 cisco 876 with 2 ISP config pbr to allow smtp from isp 1 and www fro
gezos
Hello
I have 2 cisco 876 , 2 isp one windows 2003 server as the gateway to the internet. I have 16 real ip for each ISP.
I want to configure the PBR to route smtp to ISP 1 and the www, pptp to isp 2.
It is possible that.. I Read some documents that with pbr i can do that
10 Replies 10
paolo bevilacqua
Yes, it's definitely possible.
mohammedmahmoud
Level 11
Level 11
Yes go ahead, and please do not hesitate for any further questions:
Policy-Based Routing
http://www.cisco.com/warp/public/732/Tech/plicy_wp.htm
Configuring Policy-Based Routing
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfpbr.htm
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
OK i will try and i will tell you the results
It's possible , however your smtp server then have to be configured with an ip from isp 1 ,and server traffic to isp 2 must come from a server configured with an ip in the scope "owned" by isp 2..
For servers that do not need to be reached initiating communication from Internet,
you just have to set up NAT overloading.
BR,
Bjornarsb
I do the following config on the first cisco
But seems something going wrong
sho run
Building configuration...
Current configuration : 4934 bytes
version 12.4
no service pad
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
ip cef
no ip domain lookup
ip domain name yourdomain.com
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no snmp trap link-status
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
switchport access vlan 2
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 62.xxx.38.17 255.255.255.240
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Vlan2
ip address 194.xxx.21.45 255.255.255.240
ip nat outside
ip policy route-map forthnet
interface Dialer0
ip address negotiated
encapsulation ppp
ip policy route-map otenet
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname megadis@otenet.gr
ppp chap password 0 megadis1
ppp pap sent-username megadis@otenet.gr password 0 megadis1
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 194.xxx.21.33
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source route-map forthnet interface Vlan2 overload
access-list 101 permit tcp any eq smtp any
access-list 102 permit tcp any eq www any
dialer-list 1 protocol ip permit
no cdp run
route-map otenet permit 10
match ip address 101
set interface Dialer0
route-map forthnet permit 10
match ip address 102
set ip next-hop 194.xxx.21.33
the second router is conected on port fa03 of the main and do routing with real ip from the second provider
Hi !
Nice going , you just need to change:
to
access-list 102 permit tcp any any eq www
BR,
Bjornarsb
I do it
But i see that the www does not work
I do nat in the direction vlan2 because i have real ip from the two ISP ..
If vlan1 is ISP 1 and vlan2 is ISP 2 it should work.
You should not use same adm distance for your default gateways:
Use
ip route 0.0.0.0 0.0.0.0 194.xxx.21.33 222
Post a sh ip nat translations.
BR,
Bjornarsb
i fix the roure
but the same all the trafic do to dialer 0
in the sh ip nat translation
i did not see any thing is blank
the sh ip nat stat.. is
yourname#sho ip nat statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
Vlan2
Inside interfaces:
Vlan1
Hits: 38 Misses: 0
CEF Translated packets: 11, CEF Punted packets: 0
Expired translations: 9
Dynamic mappings:
-- Inside Source
[Id: 2] route-map forthnet interface Vlan2 refcount 0
Queued Packets: 0
Have any one any ideal about this ?
