OSPF Network Question
ten
Will this work for an OSPF configuration?
network 10.1.0.0 0.0.255.255 area 0
network 10.1.5.0 0.0.0.255 area 1
In other words will the more specfic wildcard take priority ?
Edison Ortiz
"In other words will the more specfic wildcard take priority ? "
Yes.
answanso
Yes, while the wild cards are used to put interfaces into OSPF, they work very similar to a routing protocol, meaning when it makes its decision, the longest match will be installed. In this case when you enter "network 10.1.5.0 0.0.0.255 area 1" you will se a log message saying that the interface matching that prefix has left 0 and moved into 1.
Anthony
