Is this 3550-image able to do BGP and OSPF?
Answered Question
May 25th, 2007
Hi, using the Cisco feature tool set, I see that the respective image below does support "IP Routing". Does that mean that BGP and OSPF is supported in this 3550 switch-image? I didn't see BGP listed there and I will need to configure BGP and possibly OSPF as well.
Switch model number:WS-C3550-24-SMI
current image:
c3550-i9q3l2-mz.12.1-22.EA1a.bin
Search Results
Image Info
Image Name c3550-i9q3l2-mz.12.1-22.EA1a.bin
DRAM / Min Flash 64 / 16
Enterprise Product Number
Compare Images View MIBs Release Notes Image Download Information
Features
Address Resolution Protocol (ARP)
AutoQoS - VoIP
CDP (Cisco Discovery Protocol) Version 2
Clear Counters Per Port
CLI String Search
Commented IP Access List Entries
DHCP Client
DHCP Server
DHCP Snooping
Enhanced Password Security
ErrDisable Reactivation Per Port
ErrDisable timeout
FTP Support for Downloading Software Images
HSRP - Hot Standby Router Protocol
HTTP Security
IEEE 802.1Q VLAN Trunking
IEEE 802.1W Spanning Tree Rapid Reconfiguration
IEEE 802.1x - VLAN Assignment
IEEE 802.1x Authenticator
IEEE 802.1x RADIUS Accounting
IEEE 802.3ad Link Aggregation (LACP)
IGMP Fast Leave
IGMP Snooping
IGMP Throttling
Interface Range Specification
IP Named Access Control List
IP Routing
IP Summary Address for RIPv2
Jumbo Frames
Link Aggregation Control Protocol (LACP) (802.3ad) for Gigabit Interfaces
Network Time Protocol (NTP)
Packet-Based Storm Control
Pagp/UDLD/LACP L2 tunneling
Parse Bookmarks
RADIUS
Reduced MAC Address Usage
Remote SPAN (RSPAN)
RIP
RMON events and alarms
Smart Port
SNMP (Simple Network Management Protocol)
SNMPv2C
SNMPv3 (SNMP Version 3)
Spanning Tree Protocol (STP)
Spanning Tree Protocol (STP) - Backbone Fast Convergence
Spanning Tree Protocol (STP) - Loop Guard
Spanning Tree Protocol (STP) - Portfast BPDU Guard
Spanning Tree Protocol (STP) - Root Guard
Spanning Tree Protocol (STP) - Uplink Fast Convergence
Spanning Tree Protocol (STP) Extension
Standard IP Access List Logging
Support for 4096 VLAN IDs
Switch Port Analyzer (SPAN)
Tacacs SENDAUTH function
Tacacs Single Connection
TACACS+
Time-Based Access Lists Using Time Ranges
Trusted boundary (extended trust for CDP devices)
Unicast Mac Filtering
Correct Answer by ankbhasi about 9 years 11 months ago
Hi Friend,
You are having SMI switch which provides basic ip routing capability like support of static routes and routing protocol like RIP.
But if you want all advance routing functionality you can upgrade this switch with EMI image.
EMI image will support OSPF,BGP as well as EIGRP.
Have a look at this link
http://www.cisco.com/en/US/products/hw/switches/ps646/products_qanda_item09186a00800913d3.shtml
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
Correct Answer
ankbhasi Fri, 05/25/2007 - 06:34
  • Cisco Employee,
Hi Friend,
Ankur
