interface fastehernet on router 831
May 25th, 2007
hi,
i want set ip adress to fastethernet port cisco 831 router, but he give this msg:
IP addresses may not be configured on L2 links.
how can i solve this plz.
Richard Burts Fri, 05/25/2007 - 06:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The 831 router includes the fastethernet ports in a small switch. So the fastethernet interfaces are layer 2 switch ports and you can not configure IP addresses on layer 2 ports. There is a VLAN interface and it is on the VLAN interface that you configure the IP address.
Rick
yoyo_the_king Fri, 05/25/2007 - 07:09
hi,
i want connect this router with 2 network.
how can i do this.
what interfaces must be configured?
maybe eth 0 and eth 1 ?????
nikolay-shopik Fri, 05/25/2007 - 07:17
You are talkin about external and internal network? If so you need configure FA4 interface and Vlan 1 interface ip address that's it
yoyo_the_king Fri, 05/25/2007 - 07:22
hi,
yes, but there isn't possibility to configure vlan.
he don't accept "interf vlan" command.
nikolay-shopik Fri, 05/25/2007 - 07:24
what it answerers on command
interface ?
what type of interfaces its support?
yoyo_the_king Fri, 05/25/2007 - 07:28
this is the answer of "interf ?" :
async , BVI , CDMA-Ix , CTunnel , Dialer , Ethernet , FastEthernet , Group-Async , Lex , Loopback , Multilink , Null , Tunnel , Vif , Virtual-PPP , Virtual-Template , Virtual-TokenRing , range.
yoyo_the_king Fri, 05/25/2007 - 08:01
this is the result of sh vers:
sh ver
Cisco IOS Software, C831 Software (C831-K9O3SY6-M), Version 12.4(11)T1, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 26-Jan-07 00:07 by prod_rel_team
ROM: System Bootstrap, Version 12.2(11r)YV5, RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 38 minutes
System image file is "flash:c831-k9o3sy6-mz.124-11.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
--More-- http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
[email protected].
Cisco C831 (MPC857DSL) processor (revision 0x500) with 58983K/6553K bytes of memory.
Processor board ID FOC10154UCF (1088755702), with hardware revision 0000
Chassis serial number FCZ1017201J
CPU rev number 7
3 Ethernet interfaces
4 FastEthernet interfaces
128K bytes of NVRAM.
12288K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Router#
nikolay-shopik Fri, 05/25/2007 - 08:21
I suppose you have three L3 interfaces with name E0, E1, E2 and four FA0-4 interfaces on back of your router is that correct?
if so do - sh ip int bri
E0 should same range as all FA ports
E1 will be your external port
yoyo_the_king Fri, 05/25/2007 - 08:28
yes it's right,
plz, haw can'i connect the router and what interface i must configure?
nikolay-shopik Fri, 05/25/2007 - 08:35
configure E0 as your internal IF, and E1 as your external IF.
As I remeber E0 share connectivity with FA ports on this model. just try setup ip address on E0 interface connect something on any FA ports and ping E0 IF.
yoyo_the_king Fri, 05/25/2007 - 09:39
hi,
1)i configure eth0 with 10.5.10.1/24
and i connect pc1 to this interface with 10.5.10.2
2)i configure eth1 with 212.217.93.195/28
and i connect pc2 to this interface with 212.217.93.194
each pc ping his interface.
but i can't ping pc1 from pc2 or inverse.
why.
yoyo_the_king Wed, 05/30/2007 - 01:48
hi,
i can ping eth0 and eth1.
if i do "telnet 212.217.93.195" it 's work fine
but with "telnet 10.5.10.1" that's not work.
i don't know if it is normal or no.
