CSS Server initiated flows, NAT Bypass
May 25th, 2007
I've been trying for two days to understand how no to NAT server initiated flows.
The IPERF servers always sees the VIP as source address. I would like to see the real server's IP as source address.
I don't see what wrong in my config.
Here's what I got :
vlan 101, 10.0.2.0/24. PC 10.0.2.220. The pc Is running iperf as server on port tcp 5001. DFGW is the CSS.
CSS : see below for config.
VLAN 100, 10.0.1.0/24. server 10.0.1.101 initiates a tcp connection to 10.0.2.220 on port 5001.
!Generated on 05/25/2007 15:53:44
!Active version: sg0810109s
configure
!*************************** GLOBAL ***************************
acl enable
logging subsystem natmgr level debug-7
logging subsystem portmapper level debug-7
!************************* INTERFACE *************************
interface 1/1
trunk
vlan 1
default-vlan
vlan 100
vlan 101
!************************** CIRCUIT **************************
circuit VLAN100
ip address 10.0.1.200 255.255.255.0
ip virtual-router 1 priority 150 preempt
ip redundant-interface 1 10.0.1.1
ip critical-reporter 1 r1
circuit VLAN101
ip address 10.0.2.200 255.255.255.0
ip virtual-router 2 priority 150 preempt
ip redundant-interface 2 10.0.2.100
ip redundant-vip 2 10.0.2.50
ip critical-reporter 2 r1
!************************** REPORTER **************************
reporter r1
type vrid-peering
vrid 10.0.2.200 2
vrid 10.0.1.200 1
active
!************************** SERVICE **************************
service web1
ip address 10.0.1.101
keepalive type ssl
active
service web2
ip address 10.0.1.102
keepalive type ssl
active
!*************************** OWNER ***************************
owner lab
content web
add service web1
add service web2
port 443
protocol tcp
advanced-balance sticky-srcip
sticky-inact-timeout 120
vip address 10.0.2.50
active
!*************************** GROUP ***************************
group lab
add service web1
active
!**************************** ACL ****************************
acl 1
clause 10 permit any any destination any sourcegroup lab
clause 3 bypass tcp any destination any eq 5001
apply circuit-(VLAN100)
acl 2
clause 1 permit any any destination any
apply circuit-(VLAN101)
Here's what I have in iperf (client side)
D:\iperf>iperf.exe -s
Server listening on TCP port 5001
TCP window size: 8.00 KByte (default)
[1860] local 10.0.2.220 port 5001 connected with 10.0.2.50 port 3174
[ ID] Interval Transfer Bandwidth
[1860] 0.0-10.0 sec 35.8 MBytes 29.9 Mbits/sec
Server side :
C:\>iperf -c 10.0.2.220
Client connecting to 10.0.2.220, TCP port 5001
[884] local 10.0.1.101 port 1116 connected with 10.0.2.220 port 5001
[884] 0.0-10.0 sec 35.8 MBytes 29.9 Mbits/sec
lionellemaire Tue, 05/29/2007 - 03:50
Problem solved by Cisco TAC.
I had to remove the add service in the group config and
change the ACL with
acl 1
clause 100 permit any any destination any sourcegroup lab
clause 3 bypass any 10.0.1.105 255.255.255.255 destination 10.0.2.221 255.255.255.255
