Isolate VLANs (1 for public, 1 for Private) - using WAP
May 25th, 2007
Need the following objectives:
Need 1 WAP Cisco 1130 to have 2 SSID's and each one it's own separate VLAN.
- Vlan 18 is going to for employess
- Vlan 19 is going to be "public" it will only have access to Internet
I have 1 vlan for internet which is Vlan 154
I have Vlan 100 is for the servers
- Vlan 18 should comunicate with both of them.
- Vlan 19 should only communicate with the internet Vlan, 154 but should also get a DHCP address from the server wich is 192.168.100.200
I have a Cisco 3560 Switch.
Help! How to isolate the VLan?
manojr2005 Sun, 05/27/2007 - 03:25
is you 3560 a layer 3 syitch ? if yes then for the guest Vlan provide the ip helper address 192.168.100.200, create a ACL deny any any , then create acl Permit any host 192.168.100.200, this is to communicate with this server to get the DHCP. asign this Access group to the vlan 100 as in bound.
